I can see that you've truly lost the plot.....Balance and sanity over compulsive obsessiveness ?
I find this too. Since my system moved into the "higher end" I find the resolution and clarity so good that I can listen at lower levels if I want.There's a lot to be said for medium volumes with really good equipment. Amplifiers can work entirely in Class A for a start.
So...how come you are always changing your kit ? When does the satisfaction begin, and dissatisfaction stop ?I find this too. Since my system moved into the "higher end" I find the resolution and clarity so good that I can listen at lower levels if I want.
Back in the day I used to have to really crank up my "mid-fi" system otherwise it sounded flat and very boring.
AKAIK I read that horns are the best for low-level listening, which would match well to your nice 300B amp?
Cynically - have you thought of headphones? I experimented for a while but I really don't like them much.So where do I go from here?
Are my ideas about speakers and amps having a point where they start to "work" correct? And do sensitive speakers work sooner as the volume is turned up?
Should I be looking for more (!) sensitive speakers to make the most of my compromises? And if so, what are the options?
Absolutely do what you enjoy most, which includes if you find applying a bass or treble boost negatively impacts frequencies in between too much. This will very much come down to the quality of the hardware used.That's one way of looking at it, but not what I'd want for myself. I prefer a dip in highs and lows to compromising the clarity and tonality of the majority of the frequencies. There is no total accuracy in sound reproduction - you just have choices and the choices have consequences.
AKAIK horns are the best for low-level listening, which would match well to your nice 300B amp?
We share listening so headphones are a no, no. Plus I'm not keen.Cynically - have you thought of headphones? I experimented for a while but I really don't like them much.
Yes, I think you are right in looking at high sensitivity speakers and, judging from how you describe your room problems, prhaps very directional ones. This leads me to suggest horns such as Avantgarde. These offer exceptionally good / emgaging / even exciting low volume sound and are the most tolerant type of speaker regarding room acoustics. The disadvantage of course is their small sweet spot.
Peter
What is the baseline figure when everything is silent in your room?Interesting thread, I now live in a top floor flat and am very mindful of disturbing the neighbours. I am trying to craft a system around low volume levels and small amounts of bass. However I think the biggest change I have made is in the music I listen too, a lot more simple vocal music without the driving baselines that I still love. I have explored music that I would never of listened to in the past and it has expanded my musical tastes.
My personal opinion is that certain types of music simply have to be played loud, when I get the urge for punk or even Floyd then I get the headphones on, it is simply a situation I have to accept. But when I know my neighbours out then I get some time to crank up the volume!
I should say my system is very modest consisting of a Rotel Tribute amp (my beloved Kraken is ill) and Monopulse 32s speakers placed on stone slabs in an attempt to stop the bass reverberating through the floor. I was listening to a lot of female vocals last night like Tapestry and it sounded very good never going over a registered 60db on the phone app I use.
Bloody thread disruptorsHave you tried different cables?
Mine is 24db, 60db is fine but generally I play average 70-80 level with peaks going higher.What is the baseline figure when everything is silent in your room?
I have just tried listening with a peak of 60db & I found it very difficult & not really enjoyable due to straining to follow certain passages.
We are not attached & have no perceptible noise from outside yet the baseline is 41db; in normal listening I get lows of 61db, highs of pushing 80db & an average of 73db, it doesn't sound loud at all & I could comfortably go much higher if I wished. This is using a phone app so mught not be the most accurate, but still.
Thanks, but I have no problems with my listening levels & my amp has way more power than I will ever need. I was just trying to replicate how Baloo666 was listening is all.Mine is 24db, 60db is fine but generally I play average 70-80 level with peaks going higher.
A more powerful amp. may help.
It is quiet but not unusual, with the central heating boiler on its about 25db.Thanks, but I have no problems with my listening levels & my amp has way more power than I will ever need. I was just trying to replicate how Baloo666 was listening is all.
24db is mighty low isn't it for ambient noise? As I said we have no road noise or any footfall issues, we can make a lot of noise here without upsetting anyone at all, but I do try to keep it reasonable.
Just tried it with nothing on in my room the average12.3 db with a max of 45db when a motorbike went by. Tried Chris Jones Smoke and Noise and sounds great at average 49bd with peaks of 63db. Using app called Sound Meter on the phone. Nearfield listening with speakers about 2 meters away measuring volume from listening point.What is the baseline figure when everything is silent in your room?
Don't even think about it. They can so easily damage your hearing and give you tinnitus. Trust me, I'm a victimCynically - have you thought of headphones? I experimented for a while but I really don't like them much.
