Spectrum analyzer level problem
wonky1969
338
197
stondon massey
jason ruse
Hi all,
I currently use a bdp-131 spectrum analyzer on the main outputs,just coz I'm an eighties guy who missed seeing dancing lights,it works great at higher volumes,but due to a hearing condition called hyperaccousis, which prevents me from listening at higher volumes,it's rendered virtually useless.
So my question is,can the output to the analyzer be increased, without high volume?
Any pointers?
Strider
Show me your Fooses
5,605
3,570
Here and there
Mark
Can you turn up the sensitivity? Looking at the rear its Line/XLR in out just monitoring the input and not related to how 'loud' you're playing music..
What other kit do you have?
wonky1969
338
197
stondon massey
jason ruse
Yes, sensitivity is at the highest level,at over 60db it's fine,I generally listen between 30-40db, hence my problem.
I have both rca and xlr out on my pre,xlr to my main active speakers,and the rca feed my sub,the rca out from the sub feeds the analyzer.
audio-PHIL-e,no tape outputs I'm afraid
wonky1969
338
197
stondon massey
jason ruse
Just found this on Amazon
multicomp PRO Stereo Line Level Amplifier Adjustable 0 ~ 15dB Gain; Product Range:-; Plug Type:-​
Think it will solve my issue, won't get it yet due to cash flow problems,when I do,I will report my findings,if of use to anyone
