From the original article Over the Limit
But what is going on with Vapor Trails? The numbers quickly report the truth we were hearing with our ears. The average volume is a whopping 4.5 dB louder than Counterparts. But where Counterparts was able to achieve a 4.5 dB volume boost with almost no increase in audible distortion, in the Vapor Trails sample almost every peak is clipped, many of them severely so. And, as we shall see, the limiting is so severe that the songs have no punch, and just slam out of the speakers like a loud blast of white noise.
What you are looking at is a serious square wave. Note in the top swing of the clipped wave how the high-frequency harmonics have had all of their peaks shaved off? This is why clipping sounds harsh. Now note how in the lower portion of that wave the bottom is just perfectly squared off? That's a pulse of white noise. Now note how all of the peaks in this signal are all hitting the top of the scale? This is why the CD has no punch. A powerful blast of the kick drum should be louder than the rest of the signal and should have a sharp transient on the front of the wave. In the case of this song, however, it just produces a quick blast of distortion and a dull thudding sensation.
If you find something else, either objectively or subjectively, then you should email the author and let him know AK. editor@prorec.com
In any case if you or anyone else doesn’t hear any distortion in the first instance then all is fine. To my ears however a clipped waveform has always sounded like distortion because that’s what it is.
