Anyone ever seen, heard or have vertically stacked ESL63's (as is common with the original ESL / 57)
If so, what was your experience or advice?
So you have have heard this working and come to that conclusion ? Ahhh no you are guessing , stacking Quads is a very long standing thing and was even part of SME owners music room for many years . There is work and skill needed to get the best results hence my advice to contact Andrew Jones for advice . Mistrust have heard stacked quads are very positive about the musical results when they do not sound anything like the 989,s .Vertical stacking of 63s is unlikely to be a good idea, as you would end up with separated point sources producing the same signal, a recipe for interference (of the constructive/destructive sort).
You could try placing them side by side but with an angle between them. You could try side by side and restrict the outer (or inner) to bass frequencies. You could find a pair of 989s...
Well if you are ever in the area of Liverpool you have an open invitation to come and listen to mine .Thanks all, sounds like 57 and 63 are fundamentally different speakers, also explains why I could find virtually nothing online ref stacked 63's.
Would like to try 57's (stacked or otherwise) one day.
I found a reference that suggested the second pair of 63s were facing sideways and fed with low levels to enhance 'ambiance'.Abject apologies like the idiot I am I read this wrong and presumed the stacks were 57,s . I have never seen it heard stacked 63 but I do know ARA at one time had stacked 57,s but we're later replaced with 63 and no idea how they were used .
