Good Afternoon
I have a pair of the original 1970's KEF 103 Reference speakers that I use daily and have owned for about four years. Ever since I bought them I have wanted to update the crossover as the originals have never been touched and are by now probably quite a bit out of alignment .
The issue I have always had is that if I change the fitted crossovers and find that it has changed the speaker voicing then it is not too easy to just reverse things.
Over two years ago I bought a full set of replacement Capacitors and resistors (I think I also bought Inductors as well but can not remember will check tonight) along with cable for a rewire and new foam strip sealant for the cabinet .
Just by chance today on checking e-bay I have been able to buy a pair of crossovers with mounting panels which means I can now sit and replace all the items at my leisure then remove the old crossovers and retain them safely in case I need to put them back rewire and replace the foam strip and I should have one updated pair of speakers .
Are there any pitfalls I should look out for ? Often more modern items are more efficient than those originally used and this can some times mean you need to change the resistor on the tweeter to get back the sparkle or tame the increased treble that you get . Should this be done by trial and error or is there a way to test for it ?
My soldering skills are not that great but should be able to manage this . Would you suggest fixing all components firmly to the circuit board ro is that not that important ?
