What is your ‘switch on’ ritual /process?
Wenge1
3,282
16,886
open the Material Skin interface
Good Lord are we still talking about starting up the HiFi ...... :ROFLMAO:
I know - sounds weird but it's just a variant of the web inteface to LMS (Logitech Media Server). Actually works very well as a means of controlling streamers that are connected to LMS (such as SBT's, PiCorePlayer,...etc.).
Good to hear Tony - especially since you been assigned to look after us Newbie WAM demonstrators at the show later this year ....... ;) :ROFLMAO:
  • Haha
Reactions: Tony_J
unclefz
34
23
Switch on source(es)
Switch on preamp (integrated amp used as a pre)
switch on phono pre if going to be used.
Switch on power amp
Select appropriate source on preamp remote
Sources.
If FM/DAB/internet select station or use what was on last time
If CD put disk in tray and close door select play.
If LP select album and place on turntable and start turntable, clean stylus, clean record, cue arm and play.
Retire to listening position with preferred (alcoholic) beverage.
oh yeah, I almost forgot TURN IT UP!!
When its all over..
Switch off power amp first.
MVJ
20,457
42,382
198
Doesn't anyone just switch on and listen to music? Rituals, tweaks, thinking about the "hi-fi set up"... Isn't all this shite spoiling the enjoyment of what the equipment is supposed to do... Help you listen to the music you enjoy???
Your quite right far to many audiophiles massively overthink things I know I did but I'm better now .
Turn it on to listen to music be it Streamer, CD or Vinyl turn it off when I've finished.
The end😝
Reactions: Stephen101
JezR
823
373
Brighton, UK
Jez
I think it's more about not blowing your tweeters up.
Reactions: Tony_J
32,873
Just like musicians don't just walk on stage and play their best number, so we enjoy the build-up to the performance. Or some BS like that.
Basically, if I don't turn everything on in order, the fundamental mass-energy relationship in the vicinity will cause a tear in the continuum and the Midlands could turn into a black hole. And before anyone says it, yes, I know...
Rayymondo
1,413
1,356
North Somerset UK
Raymond
For some strange reason my new integrated amp turns on and off with the remote for the DAC, even though they are from different manufacturers. As I generally need both turned on anyway (unless on the rare occasion of just turning amp and tuner on) it works out quite well. So for me it's all turned on and off at the same time, whether I like it or not :) (Obviously I could go over and press the buttons if I really wanted to or had a preference for the order I wanted them on or off).
bigrod
Super Wammer .. Pussy 🐈 lover
5,976
8,904
D H LAWRENCE TOWN
Julian
Switch supra 6 way extension on at wall socket …wait 2 minutes …
Jobs a gud un
Seems very boring to some posts in this thread
Reactions: Tony_J
myles
4,014
1,932
Plymouth
Myles
Streamer and DAC are always on so:
Phono
Pre
Power
Stick Paradise Radio on, go make a brew and then sit down to listen to some records.
zeta4
988
1,173
Oxford, , United Kin
Most of my stuff is self built which shows.
So
Switch on the mains. Yes I have forgotten this before.
Switch on the battery supply to the CD player. Check battery level
Switch on the CD player
Wait a couple of minutes, switch it off then on again. You may be wondering why I do this.
Its because it has a bug on the motherboard and I'm too idle to change it. At the next
switch on it boots up properly.
Switch on the valve amplifier stage and wait for a few minutes while it warms up
Then finally switch on the mosfet power buffer stage.
Finally music.
Yes my wife thinks I'm nuts as well.
ps I forgot. If I want to play vinyl that involves another couple of switch on operations.
jamesrfisher
159
409
Depends on time of day.
If it's the morning, switch on amp, set volume to desired level, choose record and switch on TT or chose a playlist and press play. Sit back, take a sip of coffee and enjoy
If it's the evening switch on amp, set volume to desired level, choose record and switch on TT or chose a playlist and press play. Sit back, take a sip of wine and enjoy
  • Haha
Reactions: MartinC and lostwin
Beyond you
Tuesday Music Night’s Est:1978
4,273
5,675
Hants
Matt
Main system in the lounge is turned on or off never left in standby. WiFi sockets to power up which are hidden behind the stack. They can be operated by Alexa, only if you remember what you’ve called each socket in the first place 😂😂😂
Second system (Powernode 2i) in the ‘Tiny Music Listening Room’ left on
Reactions: MartinC
bencat
Amplifier Destroyer
10,311
8,115
Andrew
After the alterations and subtractions on my music system to everything is now powered by a single monster power unit (sort of posh extension block) it is just turn on at the wall and wait for it to run through the checks then just switch on .
Reactions: Beyond you
JAD
342
749
98
Tonight it has been:-
16:10 walk down from my WFH podule aka, top of the landing. Switch on the Sugden. Walk back up the stairs, continue WFH.
17:00 log off and into my lounge wear aka, jammies
17:03 chose two Gene Clark cd’s walk down stairs
17:05 partner in crime hands me a cider.
17:06 feet up and listen
enjoy your weekends everybody whatever you are up to
