One of the best power amps Technics ever made, hugely under the radar. Looks nothing special until you pop the lid (and clock the fact that it consume[SIZE=11pt]s 900W when at full pelt!).[/SIZE]
Loudspeaker terminals replaced (previous owner), in excellent working order. A fellow SE-A50 owner says he flogged his Krell after A-B-ing the two. No surprise at all.
Specifications
Power output: 125 watts per channel into 8Ω (stereo), 350 watts into 8Ω (mono)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.002%
Damping factor: 100
Input sensitivity: 1V
Signal to noise ratio: 105dB
Speaker load impedance: 4Ω to 16Ω
Dimensions: 430 x 161 x 408mm
Weight: 16.6kg
Price is £450, collection only from Bedford please.
Specifications
Damping factor: 100
Weight: 16.6kg
