Who has this sort TV? Have you noticed a faint high frequency noise when on mute in a very quiet room?
I've noticed this and now cannot unhear it.
Was much worse when I had my Xbox series x on so I've returned it thinking it was the poor Xbox. Now with the stock issues I have no Xbox,
Looked up online and many experiences are similar. It's really bugging me. If the sound is on it can't be heard but if this is a fault however small I want rid of it
Apart from that the picture is stunning
Without trying to curse you all with this annoyance as many of you might not even be aware or even susceptible to the noise
Can some of you check and see
Your ear needs to be close to the bottom left side to pick it up, after which once in tune you can pick it up from afar
