I was hoping to find somewhere localish enough to drop off and pick up in person. I guess I could try myself first and if I stuff it up then seek help! I expect the loose speaker connection is just a case of tightening a nut on the inside.I nearly sent my AR6s to Wilmslow Audio in Leicestershire, but decided to have a go myself, successfully I'm happy to say. Might be worth giving them a call.
Yes. Mine have that issue too. I can't be bothered to sort it so when I connect them I just use long nose pliers to hold one nut while I tighten the other.I expect the loose speaker connection is just a case of tightening a nut on the inside.
I’d Have a go yourself. The cost of a third party repairer would not really be worth it. There’s a ton of videos online to help you through![]()
