I think there is a lot of foo regarding record / disc clamps / stabilisers
A record weight that doesn’t clamp onto the spindle I get to a point , but they rarely address the problem of warped records unless the record is really thin .. on older quality thicker discs you will never be able to flatten a warp towards the edge of the disc as it would take several kgs of pressure from the centre to reach the edge
You can apply more pressure with a clamp that clamps to the spindle .. but why would you want to clamp the record disc to the spindle bearing.
My basis signature came with the basis clamp but I very rarely use it . Mainly because my collection consists of early vinyl which is a lot stiffer by modern day standards .
Do you use one regularly and what are your thoughts
