Right;
I installed this Buster Desktop on a rpi3b+
https://downloads.raspberrypi.org/raspios_armhf/images/raspios_armhf-2021-05-28/2021-05-07-raspios-buster-armhf.zip
using the raspberrypi Image Maker Tool on a Windows 10 Pro Desktop, this let me configure SSH easily.
Connected the pi up to a monitor and fired it up.
When running I connected by SSH and used sudo raspi-config to enable VNC.
I connected to the rpi via VNC and did not run an update, nor "wait for network"
I used Chromium to navigate to Mysqueezebox.com and downloaded logitechmediaserver_8.2.0_arm.deb
right clicked the file and used Package Install
Connected to LMS from the Windows Desktop and installed Radio Paradise
Checked playback worked.
Then I stopped the Touch, left it displaying the time, and shutdown the pi, this was at 14:30
At 1508 I restarted the rpi
Went to Touch screen, tapped on, selected My Apps > Radio Paradise > play
stopped play and stopped the Touch
Time showing 14:33 when actual time is 15:11
Tapped start on the touch, playback begain from Radio paradise
I have just stopped playback on the Touch, screen is showing 14:51 and time is 15:29
Connect by terminal
pi@Bodgit:~ $ sudo /etc/init.d/logitechmediaserver restart
[....] Restarting logitechmediaserver (via systemctl): logitechmediaserver.servi[ .k
pi@Bodgit:~ $
and time has updated.
I checked the server log, but nothing stood out
I did a factory restart on the Touch (disconnecting the EDO Applet) and selected a Radio as player.
Started playback on the Radio
I used the Touch to stop playback on the Radio, which went to 15:46
The Touch went to 3:46
I shut down the rpi via VNC
I'll come back later with another update
