I've been pondering what to do that will be a bit different & potentially interesting for my next build. I've had a thought in the back of my brain for a while that some kind of TL might fit the bill, and I have to hand a pair of the Tannoy Autograph Mini drivers which are visually quite interesting (although have a somewhat "interesting" FR curve!). Browsing idly through the Ether I revisited the Frugal Horn website and came across The Metronome:
https://www.frugal-horn.com/metronome.html
The site gives a variety of dimensions for drivers of various sizes - all FR drivers and mostly Fostex, but I don't see why it shouldn't be possible to adapt the idea for the Tannoy drivers assuming that they will fit (they are a bit deeper front to back than the Fostex of similar size). I'm sure they will need a bit of sub assistance, because they will likely roll off pretty fast below the driver's resonant frequency (90 Hz) but that is always do-able.
Anyone out there done the Metronome thing?
