Nagaoka GL-602 Crystal Turntable Mat
aniki
79
Bristol, England
Nagaoka GL-602 Crystal Turntable Mat.
Having tried virtually every combination of weird and wonderful turntable mat ever conceived, this is quite simply the best mat I've ever used. No longer produced and getting very hard to find.
This one is perfect and in original packaging. Offered here for £90 inc. delivery within UK.
Product Description
Nagaoka crystal turntable mat for improved sound quality from your record turntable. The turntable mat supplied by the record player makers often absorbs a lot of the sound stored in the records groove. It is well known that by using different materials to manufacture the record mat, you can greatly improve the sound experienced by reducing the amount of information being lost in the mat.
Nagaoka has pioneered the use of crystal for record player mats. The manufacturing of these mats has been enabled by the expertise of Nagaoka in the field of grinding hard materials. The Nagaoka Crystal mat has a diameter of 290 mm, 6 mm thick and weighs about 1 KG. The center has been depressed slightly in order to offer space for the slightly thicker part of the record, the label, ensuring full contact between the record and the mat.
The Nagaoka Crystal mat is lighter and harder than aluminum and coated with a special technique. It helps produce a crystal clear sound with excellent separation.
PLEASE NOTE: The small puck which was originally included is not supplied due to the rubber having deteriorated over time.
goldenfi773
