@Wpjs the oil in the bearing housing not only lubricates the thrust pad and bearing tip, but when the bearing is lowered into the housing, oil is forced up to lubricate the entire length of the spindle. Indeed, the dealer will fill with sufficient oil to cause a slight overflow, which is caught on a small tissue, ensuring the bearing is completely full.
’troll
