Dear all,
I have a Pi Zero and aim to install LMS in order to use the BBC Sounds app with my Squeezebox Touch.
I've installed the 'full' pi OS, having bought an SD card with NOOBS installed. I downloaded the LMS package and ran it, but nothing obvious has appeared, so I don't know if it worked or not
Is there an Idiot's guide anywhere for installation and setup?
If it makes any difference to anything, I don't have a laptop or pc, so unless it can be done on the Pi, I have no means of 'burning' anything onto an SD card.
I'm a software developer, so do have some IT skills, but this is all new to me!
Thanks,
Andrew
Thanks,
Andrew
