Somebody please add up the prices on this. Tranquility pods optional.Surely, the top system now would be
LP12
Klimax DSM/3 Hub
X2 Klimax Exaktboxes
X6 Solos
360s
I am not even going to think about the prices.
Edit. I forgot you’d need ten Tranquility Pods too![]()
Including cables, it comes to just over £200,000.Somebody please add up the prices on this. Tranquility pods optional.
I don’t think so, the 360 is a three way + bass and the klimax exaktbox has only six outputs. So you need two.I’m quite interested if they can be used with one Klimax Exaktbox. Maybe Exaktlink for the bass input? I’ll try and find out.
From what I heard Philip Budd was never a fan of the 3K array. With a 19mm tweeter there is no need for a super tweeter. Crossover complexity is reduced as is the need for as many amplifiers.The 3K isn't a 3K anymore, but it's still three.
Yes, the unannounced speaker we aren't able to talk about until after the embargo ends on April 21st only needs one Klimax Exaktbox crossover. It is only the three ways that are passive, the dual bass drivers are always active with their own special amp and their crossover is part of that. This was made quite clear at the event.I’m quite interested if they can be used with one Klimax Exaktbox. Maybe Exaktlink for the bass input? I’ll try and find out.
But you need a source (so an Organik dac) for the bass part of the music. No ?
Like today with 350 and Komris…
That’s what I presumed. Three Exakt channels for external power amps and one channel for the active bass. This makes four for each stereo channel so two Exaktboxes would be required.But you need a source (so an Organik dac) for the bass part of the music. No ?
Like today with 350 and Komris…![]()
Perhaps, the bass has a Cat 6 type input for the Exakt signal. If that’s the case, one Exaktbox may suffice.
No doubt all will become clear when Linn announce more information about the product .
Even if it works with one Exaktbox, two may sound better.
Even with a Cat 6 on the bass part of the 360, it needs to be feed with a bass only signal, so a separate Organik dac…That’s what I presumed. Three Exakt channels for external power amps and one channel for the active bass. This makes four for each stereo channel so two Exaktboxes would be required.
Or… the Organik dac for the bass is INSIDE the speaker, then just connected with Exact link?
I think that 360 would work like 350. If so you will have 4 binding post (with the need of an amplified signal) and an XLR for amplified bass. For this reason you will need a Klimax exaktbox for each speaker and 4 amplification channel that could be 4 solo or 2 twin each speaker.
No it only needs 6 channels of amplification. The bass units have onboard amplification.I think that 360 would work like 350. If so you will have 4 binding post (with the need of an amplified signal) and an XLR for amplified bass. For this reason you will need a Klimax exaktbox for each speaker and 4 amplification channel that could be 4 solo or 2 twin each speaker.
I’m sorry I only learned yesterday that the 360 woofers do not need to be connected to the exaktbox (unlike the 350 that require it) because they use a new technology that allows them to connect via exakt link.I don’t think so, the 360 is a three way + bass and the klimax exaktbox has only six outputs. So you need two.
So it’s like a pure three way so you only need one exaktbox.
Sorry for the inaccuracy.
Are you sure? This pic would indicate it is connected like the 350 using 3-speaker cables and a XLR (but .I’m sorry I only learned yesterday that the 360 woofers do not need to be connected to the exaktbox (unlike the 350 that require it) because they use a new technology that allows them to connect via exakt link.
With the 350 it is so, but with the 360 the connection to the exaktbox is not required via the XLR connector only through exaktlink.Are you sure? This pic would indicate it is connected like the 350 using 3-speaker cables and a XLR (but .
I assume that the photo refers to a 350...
No it is a 360 (3 speaker connector pairs) but this speaker is run in passive mode. Still confused…could be that when you convert a passive to aktive, a section of the back plate is changed and exaktlink is added. The speakers would need to be ”daisy chained” since the Exact box only has one exaktlink out.With the 350 it is so, but with the 360 the connection to the exaktbox is not required via the XLR connector only through exaktlink.
That photo doesn't look like a 350 because there are only three pairs of loudspeaker cable. A 350 would have four like a Komri.
The one shown in the picture is a passive setup, so I think in this case the XLR is necessary for connecting woofers.No it is a 360 (3 speaker connector pairs) but this speaker is run in passive mode. Still confused…could be that when you convert a passive to aktive, a section of the back plate is changed and exaktlink is added. The speakers would need to be ”daisy chained” since the Exact box only has one exaktlink out.
The bass units can be connected using either XLR or Exakt linkThe one shown in the picture is a passive setup, so I think in this case the XLR is necessary for connecting woofers.
Hope they offer a 350 upgrade kit for some of the stuff, new amps, Utopik etc. lol
Some more info on the show can be read here:
https://www.linnhaus.de/linn50years/
Including " Wer Linn kennt, weiß aber, dass auf die exclusiven Neuheiten im Hochpreis-Segment immer auch bezahlbarere folgen." = there will be more affordable versions coming. Also indications that there will be a busy year with exciting stuff
Similar threads
- Replies
- 8
- Replies
- 19
- Replies
- 50
- Replies
- 30
