Every now and then (but not consistent) I hear clicks originating from my Klimax 350s Organik when playing music. These clicks are similar (but somehow appear to be somewhat softer) to the ones that the speakers manifest when starting up. Sometimes only the left speaker does it, sometimes the right one and sometimes also in a subsequent way. Of course I can go to the support route but I was wondering if any of you also encountered this (it may be a known issue).
What I did to rule out the usual suspects:
1. Fallback & reload speakers;
2. Exakt->Replaced ethernet cables (noname) with Blue Jeans Cable 6a cables (I noticed a thread posted a long time ago pointing to more or less the same issue caused by ethernet cables not up to spec);
3. Fallback & reload DSM.
My speakers have been upgraded to Organik by the dealer, and he informed me the 2 bottom screws of the circuit boards sometimes caused issues (sounds because of heat/cold expand/shrink effects) and they have been removed already.
Any thoughts?
Any thoughts?
