Help - fuzzy brain moment…
lostwin
Tinker Bod
2,314
2,249
Folkestone, Kent
System has developed an intermittent fault on one channel with very bad break up of the signal.
My brain is a bit fuzzy this morning, I put it down to the England game last night inducing a temporary shutdown- Stones, Maguire, Stones, Maguire, Stones, Magu…zzzzz
I have changed over the L/R interconnect into the back of the power amp, fault moves speaker. So speakers are OK, but does that also mean power amp is ok? Do I now work back through the pre and phono doing the same cable switch until the fault remains in the same speaker?
Anyone’s brain sharper than mine this morning?
  • Mind Blown
Reactions: JANDL100
Sotosound
772
589
98
Buckinghamshire
Ian
The power amp is ok if the noise changes sides when you swap preamp out channels.
Are you using one source or multiple sources?
If you are using one source, then swap the lead going into the preamp and see if the problem moves.
If you are using multiple sources then are you experiencing the same problem with all sources?
lostwin
Tinker Bod
2,314
2,249
Folkestone, Kent
Single source - TT
Sounds like I’m on the right track then - swap I/C lead channels working upstream until fault stays in same speaker
Sotosound
772
589
98
Buckinghamshire
Ian
Great, thanks. Intermittent faults are the worst though, playing right now and sounds fine. Just got to wait.
Intermittent faults never show up when the repair man visits, so ask a repair man to move in and the fault will go away. :)
Is the preamp volume control working ok? A dodgy volume control can cause intermittent issues.
Also, see if you can hook up another source to see whether or not the problem is in the main preamp.
lostwin
Tinker Bod
2,314
2,249
Folkestone, Kent
Took a while, but back came the fault in same speaker after changing I/C channel into pre amp. So pre is the one playing up. I recently changed the 6111 valves in this, might put the old ones back to check for dodgy valve.
Reactions: Sotosound
lostwin
Tinker Bod
2,314
2,249
Folkestone, Kent
I’ll check for volume pot as well, presumably by changing volume whilst fault occurring.
Presumably, similar principles can be applied to the England team. Start by changing the forward line, if that doesn’t work , swap out the midfield and keep working backwards.
Ultimately, I think we all know that Southgate is the dodgy valve though!
Reactions: Linear and enrae8
lostwin
Tinker Bod
2,314
2,249
Folkestone, Kent
I don’t think my brain has bothered to wake up today. I have taken out my troublesome Pre and going to an integrated amp.
I have a phono and a head amp. For the life of me I can’t remember what I plug the cart leads into first. MC cart to head amp to phono MM, isn’t it……??
lostwin
Tinker Bod
2,314
2,249
Folkestone, Kent
I’ve been playing the system for the last hour - MC cart to MC phono to head amp to amp by the way!
A nagging ache from inside my head seems to think that isn’t right…
In fact I have just changed it round. Sounds better 😄
Straujk
