Has anyone upgraded the PSU of their Bluesound Node 2i. Which upgrade was it and did it make much difference.
Thank you.
Thank you.
You probably realise, but for the OP note that the point of using a better power supply is not necessarily related to mains noise. Yes one could be less susceptible to this but the real point is how clean/stable the generated DC supply to the internal circuitry is.consideration is the degree to which one’s other components are susceptible to noise from the mains. That’s not to deny that noise has an effect; having tried Wave cables one can hear the effect of noise when the cables are replaced with conventional ones. The difference, whilst worth having, isn’t huge to my ears.
Interesting point. To what degree will cleaner/stable power supply affect the sound quality, both analogue but particularly digital out from the node? Obviously, in general terms the best power supply is a good thing but at what point does it audibly affect sound quality?You probably realise, but for the OP note that the point of using a better power supply is not necessarily related to mains noise. Yes one could be less susceptible to this but the real point is how clean/stable the generated DC supply to the internal circuitry is.
I'd say that's pretty much the main point of the upgrade being discussed and so @rabski's post and the 132 page thread covers this here. The Node has a built-in switch-mode power supply which will generate its own 'noise' on the desired DC signal and proponents of linear power supplies would usually argue this is what they're trying to improve on. Linear power supplies can't convert 100% perfectly from AC to DC at the desired voltage either though and so ultimate performance is always going to come down to the particular implementation. These comments apply even with a textbook perfect mains supply with zero noise.Interesting point. To what degree will cleaner/stable power supply affect the sound quality, both analogue and digital out from the node? Obviously, in general terms the best power supply is a good thing but at what point does it audibly affect sound quality?
How useful would that screen be in practice though? My gut reaction is that looks like a middle ground that will please few. Personally I'm happier with my laptop or phone as the screen, and if my streamer had a display like the Cyrus photo I wouldn't be able to read it from my listening position anyway. There are streamers with larger colour screens that show album cover art which I wouldn't personally want but I think I can see more of the appeal of.Before I go down the upgrade path my dealer has made me aware that Cyrus will be releasing later this year a product based on the Node, but with display etc.
https://www.cyrusaudio.com/streamer-development-update/
They can both improve the sound quality. For me probably the LPSU made more difference and cost less.The key question for me would be whether buying a suitable external DAC may be a better route to an upgrade. My hunch is that it may well be.
Compared to what DAC change?They can both improve the sound quality. For me probably the LPSU made more difference and cost less.
I would not buy that, I would want a streamer from a company that has a good history of streamers. How much will it cost?Before I go down the upgrade path my dealer has made me aware that Cyrus will be releasing later this year a product based on the Node, but with display etc.
Regards
Alan
Jolida and Soncoz as in my profile.Compared to what DAC change?
What DAC is going to make a big difference?
I don't know anything about restrictions on my profile.For info. I can't see your profile. If I click to try to see it I get a message saying you've limited who can view it. Which models are those DACs?
I'm sure there are loads of DACs that could be an improvement but I think you're right they'd cost more than the PSU change. Money not spent on a PSU change could be put towards a better DAC though.
I've not owned a Node myself to comment from experience though which is why I asked you for more info. for the OP's benefit.
(I do of course like the DAC in my signature and would be surprised if it wasn't a decent step up on the Node's but at about £675 this will be more expensive than most board plus LPSU upgrades for it.)
You did say that you found differences between DACs subtle.
Some people can't hear a difference between DACs. Quite a few Node users found a difference when using a LPSU. Your DAC costs around £675? Not heard it, from the reviews probably not a huge difference between my Soncoz. With the Node I would certainly want the LPSU, without it, it sounds harsh, some music was unlistenable.I have in the past, but less so my most recent change .
Anyway, you've now nicely muddied the waters for the OP by basically having the opposite experience to @rabski . If only upgrade questions were straightforward!
