DW.
Burning in power cables
here goes ,,its all to do with which way the wire has been die drawn, and then made up, so every thing is pointing in the same direction, but what do i know ive got hideously expensive MIT cable loom,,,,, all pointing in the same direction ,,if anyone gives a f5ck
As if electrons care.
It is AC so there isn't even any 'flow', just a sort of bumping into each other.
http://www.hifiwigwam.com/showthread.php?654-The-Great-Cable-Debate
How on earth this came up in search I have no idea! Has been MIA for years ..... anyway enjoy. A classic.
Woah. 656 posts. Thanks, this may well be the cure for my insomnia.
here goes ' date=',its all to do with which way the wire has been die drawn, and then made up, so every thing is pointing in the same direction, but what do i know ive got hideously expensive MIT cable loom,,,,, all pointing in the same direction ,,if anyone gives a f5ck[/quote']
Nope.
The wire is drawn many times between electrical annealing and other processes. The manufacturers who do this are not cable makers they are people who make it by the kilometre. They don't carefully load the machine each time to note it's direction. It will have been changed several times during all this.
Also what is being given directionality during drawing? Particularly something that would not be effected by annealing.
Only if they have some type of wooden isolation built into the design to stop the vibrations entering your kit :-)
Sorry, say what?
no it isn't
and then made up,
"Made up"... good phrase.
Everything? Every what? Direction? What even do you mean?
but what do i know
Dunno..
Loom..
Direction? That's meaningless. They are cables. They can't have a direction.
:whistle:
i put mine in the oven mains plug end faceing the oven door... then its into the freezer. i wind them tight for the freezer mains end in center of the coil. job done audio bliss!
Too much Cider?
not enough! u think the acid of scrumpy will make my cables better?? i think i will stick to my fact based method:nuts:
Too much Cider?
