ob1
Squeezebox at show, wireless connection
Would it be possible for me to use Squeezebox (and MAC Mini), Can I get a WiFi connection in room at the hall?
Assuming the source material is on the Mac Mini can you just use a cable?
I never try, if it possble then I will look in to it. thx
ps I have Duet, I thought the controller need Wifi to connected to the Receiver
Last year I took an old Netgear wireless router with me, just turned off the wireless part so I didn't interfere with anybody else, and wired my PC and Squeezebox Touch with Ethernet.
As I'm not exhibiting this year, I can lend you my old router and cables if you don't have one.
S.
S.
Thank you for the offer, I do have a router but not quite clue up of what is need to be done so I will experiment this weekend and if I come stuck can I pm you with the question pls.
thx again
thx again
If you have a router and the ethernet cables, it should work straight away as there shouldn't be any passwords or other setups needed. PM me if you need any help.
S.
Ob1, the duet receiver connects via wifi to the receiver, the receiver acts as a wireless access point for this. If I search the wireless access points in my house then the receiver shows up. A simple wire then from the mac mini to the receiver should suffice. You can test it all before going, just switch off your other wireless access points first!
Many thanks :^
To connect the SB to your computer directly you will need a crossover ethernet cable. If you do it via a router, to give you wireless to the controller, then a plain ethernet cable.
if the wireless part is a no-no, then use the squeeze server on the mac.
This is all assuming that your music is on the Mac
Most computers these days will auto-detect whether they have to cross over or not, best to check before the show though!
