radiant red
Thorens TD125 MKll rebuild
I’m just about to undertake another turntable rebuild and having sorted most of what I need and want for it. The only item I am undecided on is which 9” tonearm to use..
Ive used Rega on just about everything in the past but I want to go a different route. Suggestions would be most welcome. I’m looking to spend no more than £500 on a new or used.
The cartridge that will be used is a Denon DL103R
Cheers
Audiomods 5 ?
Great arm and superb value.
TD125 & SME 3009 series 2 improved. A classic combo for good reason.
Yes, thought of the 3009 but wanted to give it a bit of a lift and modernise
12 hours ago, Idlewithnodrive said:
Audiomods 5 ?
Looks good.. not sure if it will compliment the Denon tho
I would recommend an original Mission 774 arm (not LC version) . This arm is very neutral and can handle both MM and MC coil cartirdges . It has almost complete adjustment for all aspects (VTA , Damping , Bias etc) .
I personally view this as a current bargain at the prices it sels for and it stands up to most arms in regards sound quality . A decent example given a full service would come in under £500 and sound better than most under £1500 .
Headshell weights help,  and we're up to Series 6 now :geek:
What he said - SME arms of yesteryear with knife edge bearings were built for low mass and high compliance MMs - they are not ideal with MCs but do improve is your fit the SME damping trough and paddle.
I use a Mission 774 so I am biased but do feel it is one of the best univeral arms you can buy - and what is important to me is it works well with a Decca (something the SME will not do).
I believe one or two brand new Jelco models cost less than £500.  I’ve no personal experience of them, however.
Yes, I’ve looked and had experience with them in the past. Been looking at the 550s but a bit more than what I want to spend unless one day I move it on something else.
You might get a S/H Wand classic tone arm for that money.
I use a Jelco 750D on a Michell. It really benefitted from an Audio Origami internal re-wire as well as changing the external cable to an Audio Note one. Loads more detail and better tone etc. I am also using a Yokohama headshell.
On my custom Lenco I use the new Audio Note II/II arm (not the previous modified Rega one). I bought the Audio Note arm from an SME dealer who told me that the SME would sound cumbersome by comparison. A secondhand one would be within budget.
I used to have a Raven AC with Phantom tonearm and sold it after 12 months as the Lenco/Audio Note had more grunt and sounded more musical. It really only lost out on detail.
Never had the opportunity to compare my two arms though on the same deck.
Just to add that if you get the Jelco then you need a collar from ammonite audio £51.  It holds the arm more securely.  I have the first iteration and am not familiar with the current model.
Take a look at the thread below Jonathan, it details a similar restoration I did to an already tidy TD125 Mk II:
https://hifiwigwam.com/forum/topic/120154-updating-a-standard-td125-mkii/?tab=comments#comment-2100875
I bought it with a Micro Seiki arm, but changed to a Jelco 750D and then a Jelco TK850S, both of which did a sterling job :)
Edited by orbscure
Nice info Dom.. I am steering towards Jelco.
interestingly as I am going to have a new plinth, I have thought about having one to take a 12” arm
