Minicoupeman
Amplifiers and speakers
Clearly there is a symbiosis between certain amplifiers and speakers - think Naim and Linn a long time ago.  It is not easy or cheap to experiment and while dealers are helpful their prime aim is to be commercially profitable so.....which combinations really work ( please don’t reply if either your amp or speakers are very new). For my part, ATC and Nord are a marriage made in heaven.
Super Dealer
There is no symbiosis, examine the specification and measurements of the loudspeaker, particularly the impedance curve and then choose an amplifier which is capable of properly driving it without clipping.
Keith
4 hours ago, PuritéAudio said:
symbiosis
Means living together .. of course all amps and speakers live together.
To get the best of any loudspeaker the amp used needs to be able to deliver the required current with minimum distortion and a flat frequency response.   When that happens you get Synergy (the concept that the combined value and performance of two items will be greater than the sum of the separate individual parts) not just two items living together and with luck some musical nervana.
I will not get into the Linn  Naim debate - having lived through it all in the 70s it was two companies who realised that Symbiosis worked well for them (it could be said they were virtually in bed with each other) but as to synergy between the two, well that is a matter of conjecture lol
I am starting to form an opinion that speakers with complicated lossy crossovers like perhaps but by no means exclusively the ls35a would tend to sound better on solid state, and those with a simpler crossover better on a tube amp. That doesn't mean that the ls35a will sound bad on a tube amp, just that it could sound more "natural" than its simple cross-overed counterpart.
This is a personal work in progress theory.
Keith
Or try a few combinations until you get the sound you like. It's much more fun.
  • Upvote 2
Don't think there's any definitive answer, as we all have varying tastes. The general rule of thumb, though, is to match dark with light. I've always found mixing light with light or dark with dark pushes the presentation too far in one direction or the other.
There are many great - natural mixes - and others that shouldn't work but does.
For example Arcam and Monitor Audio or PMC are soulmates. Ones that shouldn't but does IMO is Naim and MonoPulse speakers.
@CnoEvil
I think IIRC that Cno did a very detailed thread which lots of us pitched into on WHF forum regarding amp/speaker matching.
Pretty sure this got moved across.
Perhaps someone can link to this?
8 minutes ago, Amormusic said:
@CnoEvil
This is the thread attempting to describe how different brands sound:
It doesn't necessarily tell you what (sonically) works with what....but it may help avoid putting 2 bright or smooth components together.
Some brands that may work together:
Rotel/B&W
Electrocompaniet/Focal
Accuphase/Harbeth
Sugden/Proac
Arcam/PMC
MF Nu Vista/Kef Reference
 Creek/Epos
Hello there
Was talking about this at the Oxford bakeoff I have a Cyrus amp( Forward/Exciting/Analytical) with Dali speakers (Slightly Warmer than neutral) which I am happy with the sound at the moment, but as a newbie would like to know would you think this is a good match?
Cheers Frank
Edited by FrankD
5 minutes ago, FrankD said:
Hello there
Was talking about this at the Oxford bakeoff I have a Cyrus amp( Forward/Exciting/Analytical) with Dali speakers (Slightly Warmer than neutral) which I am happy with the sound at the moment, but as a newbie would like to know would think this is a good match?
Cheers Frank
It's a good match if you like it.
Imo Other brands that work well with Cyrus are Spendor/Spendor Classic or Kef R Series
Edited by CnoEvil
Having once paired ATC with Nord, I tend to agree but what brought you to the same conclusion?
Rotel/B&W
Accuphase/Harbeth
Sugden/Proac
Arcam/PMC
 Creek/Epos
That pretty much echoes what I've always said. :whistle:
I've never liked the idea of matching an overly bright amp with 'softer' speakers or vice versa. The old saying 'two wrongs don't make a right' is equally applicable to audio. Trying to fix something that sounds wrong by combining it with something else that sounds wrong is a good way to go down the path of being unable to ever get the best out of a system and also not being able to upgrade or change anything for fear of it all going pear-shaped.
  • Upvote 4
I have a superb amp playing at the moment , in one room it's way too much for me , in another different room it's absolutely glorious.  The room makes the most incredible difference to whether they work together
