Turk 182
16 bit / 44.1 khz - is it all we need ?
hi
16 bit / 44.1khz i believe was chosen as the standard for "red book cd" as this specification provides ample sound quality to reproduce music accurately.
i believe sacd was released with a higher specification but never really caught on and having done a little research the higher resolution files often sound "different" but not always "better"...
i have noted that msb technologies always demonstrate their sky high priced products using bog standard 16 bit / 44.1 khz redbook cds almost as if to prove how good they can sound.
so do we really need anything of a higher spec ?
Around 100kHz should be  minimum sampling frequency. the reconstruction filter does not really work on music, it has to make up to much, from not enough information, whatever the maths says.
today's opinion.
today's opinion.
hi dave and thanks for the reply.
so 16 bit / 44.1khz is not really a high enough spec then !
I guess this question has been beaten to death :)
And there seem to be 2 opposite views. There are those Americans across the pond, who claim improvements with higher sampling rates, so much so, that lots of folks are upsampling their CD rips to DSD and then feeding it to their dac's.
I actually do the exact opposite :D
I down convert everything to 16/44 in my roon server, then feed that to my dac.  But that is because my dac doesn't do DSD. However it does sample rates up to 24/192. So I can only comment between 16/44 and 24/192 samples of the same DSD track. And in my system , to my ears I can't hear a difference.
The difference between a good recording and a bad one is WAY more important.
  • Like 3
  • Upvote 14
I was about to say the same. Sadly the sampling frequency rarely gets a chance to be the limiting factor.
I've not spent time looking into whether higher sample rates may be beneficial or not since for me a hifi is a tool for playing available music which in physical form is still overwhelmingly red book.
Not quite. This was the best technology available at that time. In fact, the first Sony demo of 16/44.1 needed so much electronics that it would not fit into a standard case. Philips did not have reliable 16 bit technology so their first CD players were 14 bit. But in the numbers game it was considered a downer so they soon developed16 bit players. And there are tales that Herbert Van......wanted Beethovens 9th on one CD which at 74 mins meant 16/44.1 for the capacity of the optical disc.
Of course perfect sound forever was back-fitted. You could get 0-22KHz frequency response at 96 db dynamic range, who could want for more?
But there were problems with having to use brick wall filters to allow music at 20kHz through but no carrier signal at 22 kHz. And jitter and digital noise and.... thereby hangs a long tale.
Ironically that the man at the helm of Audionote does not believe in using any filters (digital or analogue) and thinks 16/44.1 is ideal. But then he uses valves which naturally roll off.
hi meninblack
so a well recorded 16 bit / 44.1 khz cd is all we really need then !
hi newlash09
so you can not detect a difference between "16/44 and 24/192" -like i have read many people can not often hear the difference so may not be needed !
hi george 47
interesting information i was not aware of - apologies all i might of opened a can of worms here !
5 minutes ago, Turk 182 said:
hi meninblack
All we really need is vinyl. :D
  • Haha 4
23 minutes ago, Turk 182 said:
hi newlash09
Hi Turk :)
I've tried down sampling the best quality DSD track i have ( Giorgio by moroder from Random access memories)  to both 16/44 and again to 24/192. And both these sample rates were fed to the same dac. And I couldn't hear a difference in the playback. It would probably take a lot better ears than me, to be able to make out the 16/44 from the 24/196, in a blind test.
And the down sampling was carried out by the roon software, running on a dedicated roon server. And both tracks were fed via the same roon end point via the same aes-ebu cable.
And the funny bit is that the dac has 2 different dac chips. A 16/44 dac chip for dedicated red book CD format, and a separate HD dac chip for 24/192. So despite 2 different dac chips in play, both the sample rates sounded indistinguishable from each other. So i believe the original quality of the record makes the most difference.
  • Upvote 2
All to do with the march of time and the improvements in technology - at the time it was the best they could do with what they had.  Now if you were going to introduce a new medium would you say it is "the best we can do with what we have but it may be a bit lacking compared to vinyl" which undoubtedly all the first generation CD players were.
I am sure if there was a mass market for improved quality (as there has been with film with the march from the original Picture Discs to DVD and now Blue Ray then CD would have been superseded by now and we would have hi res discs as the norm.  The problem is lack of market for hi res discs and so the manufacturers or CD players keep on trying to eek the best they can out of a limited format.  I suspect the future market will be in downloads and streaming which may (or may not) hot up the technology and advancement in high resolution.
This was indeed enlightening sir :)
Video is going hi-rez because on today's massive, room-dominating screens, anybody not partially-sighted can see the improvement.  So plenty of people will pay for it.
With audio, I don't see it.  SACD failed because too few people would pay a premium for something most people couldn't hear.  I can't see mainstream audio streaming services being any different.
