Sign in to follow this
studiohertz
Oyaide Tunami GPX V2 power cable
How does the sound differ from other cables you have used, bog standard or otherwise?
I would dare to say that this will be beautiful sounding cable. Glws
Compare to diy (yarbo, belden)and russ andrews cable this oyaide sounds fluid, with a bit warmth, solid bottom end and musical midrange. I've compared this oyaide to Transparent Powerlink MM2x (rrp £2000) and yes, transparent is better( more detail, more air, better background) but just slightly. I would say they have similar sound. This oyaide is a younger brother of powerlink mm2x for much less. I don't see weak points in this price range.
A couple of questions, please?
1. Does the label say 1.8 metre length?
2. Is that an EU plug, and if so, how do you use it in the UK?  (I’m assuming a travel adapter would slightly defeat the benefit?)
Thanks.
Thanks.
Hi Nopiano
Yes, original lenght 1.8 metre long.
I use eu( schuko) power distribution box rather UK ones. There is much more schuko cables on the market.
Also You can ask electrician to fit one furutech eu wall socket. In my opinion is a good to have one eu socket :)
