Is there a way to set separate default volumes when you switch between inputs? I ask because my tv is also connected to my dsm and for some odd reason needs to be quite loud compared to radio/server/Unidisc etc so when I switch from tv to music it’s way too loud.
The Unidisc preamp used to save the earlier volume per input :(
Have you tried the volume offset in Konfig for you TV source? I have mine at 10.0 for exactly the reason you describe.
Yes. In Konfig you can set separate volume offsets for each source. See the screenshot below. +/- 15 dB is the possible range.
/HB
PS. While fiddling with the attachment I saw Timster replying to this,... but I post this anyway.
Edit: The screenshot is not from Konfig, but from the web interface. The possibility to set an offset is available in both.
Edited by HansBertil
Thanks to both of you. I’ll start with +10 dB on the tv when I get home today. I doubt the numbers that depict volume on the dsm is dB. But for me the difference in display numbers is 45(music) 55-60(tv)
It is dB actually ;)
@timster - does the volume display on the mdsm actually change when you change to a tv input or is it just louder.
This is how I set it up.
No, it remains the same. Ahh, I see Hans has already answered.
So in fact the actual dB will be whatever the volume is + the offset.
