Radioham
Turntable 2 into 1 ?
Hi,
I would like to rationalise my turntable/pre-amp collection.
One deck is the Clearaudio Concept fitted with "Silver Note" Bespoke arm and a Rega 78 Mono MM Cartridge. The clear audio does 33/45/78 with electronic speed change.
The other is a Project Classic SB super pack fitted with a MC Cartridge. 33/45 is switched, but 78 requires a different belt fitting when you change speed
Both Decks the  headshells are fixed.
My Preamp (Luxman) has only one phono input which is switched MM/MC
To use both decks I used an outboard Preamp which goes into a line i/p on the pre-amp.
I wonder if you have any thoughts on the following:-
  1. Replace both decks with a turntable which has a removable headshell , the most obvious choice would be a new Techniques SL 1210GR and get a spare headshell.
  2. Fit a replacement arm to the Clearaudio which has a removable headshell (Arm is standard type Rega mounting 26mm hole)
  3. How would you rate the deck performance of Clear Audio v Techniques v Project
I dont have many 78's but the mother-in-law has quite a large selection I could inherit or borrow.
Regards
Alan
I would stick to having two decks if you let one go and change the arm you may regret it
