Sign in to follow this
Elite Audio
Octave Launch Their First Single Ended Tube Amplifier
Super Dealer
5e5570_ae76c18413bf46639f5c1d3305715273~
Experts in tube technology, Octave, have launched their very first single-ended amplifier. The V16 Single-Ended has a range of high-end elements as well as an integrated headphone amp.
Through a dedicated development process, the V16 Single-Ended combines Octave’s signature features of powerful dynamics, low noise and incredible stability. The component also achieves a 100 kHz bandwidth spec, something previously thought impossible in single-ended amplifiers.
Octave’s decision to create a single-ended amplifier with their specially developed technology is that the circuitry is desirable for its natural audio reproduction. The technology offers clarity and sonic benefits, making them perfect for high-efficiency loudspeakers and headphones.
The single ended design has a naturally harmonic sonic signature, meaning that there is an extremely lucid midrange with no crossover distortion.
Designing the V16 did not come without it’s challenges, as single-ended topology has known limitations. Level reduction in the bass and high frequencies, limited bandwidth issues, high residual noise in loudspeaker output and high temperatures during high-current in Class-A operation all had to be tackled.
After careful research and testing, Octave managed to overcome these barriers. The V16 remains linear at 10Hz, the bandwidth has been extended from 10Hz to 100 kHz, hum is reduced by specially placed electronic stabilization circuits and utilises Octave’s Ecomode technology and automatic adjustment in Class-A mode to keep the amplifier from overheating.
The component made its public debut at this year’s High End Show in Munich. The integrated amplifier will be available in the UK from Elite Audio and is set to retail at £7,495.
Features & Technical Specifications:
  • Inputs: 3 (2 x RCA Line, 1 x XLR Line)
  • Frequency response: 20Hz – 100kHz/-3dB
  • Loudspeaker Output Power: 2 x 8W @ 4 Ohm
  • Headphone Level: 3V/8V
  • Headphone Impedance: 15 – 600 Ohm
  • Dimensions: 22 x 33 x 33 cm / 8.7” x 13” x 13” (W x H x D)
  • Weight: 19.1 kg / 42 lbs
  • Tube fitting: KT 120 (standard)
  • Alternatively: KT 150, KT88, 6550, EL34
  • Features: Connection for OCTAVE Black Box, Remote Control (for volume), Pre-Out optional
  • Available Finishes: Metallic Black, Ocean Blue and Ice Grey
Elite Audio are the official UK distributor for Octave. We offer an excellent 30-day, no risk trial on selected products allowing you to try out audio components at home with your own system. A generous part exchange is also available allowing you to upgrade for less. To find out how much your old hi-fi components are worth, take our part exchange challenge now. Alternatively, you can contact Elite Audio via email: info@eliteaudiouk.com or telephone: 020 3397 1119 for more information.
