Audio Al
Help required silly question !
Hi
I am not sure if this will work and am asking advice before I try it out
I have 2 pairs of JBL L1 speakers rated at 8 ohms  and a Audio Innovations 500 amp that can use 4 / 8 / 16 ohm speakers
Could I bi wire a pair of speakers on each 16 ohm output ? or will it do damage ? :nerves::shock: :D
Serge will provide the definitive reply, but I think if they are in series you should use 16ohm, or- if in parallel- 4ohm.
Presumably the second pair will be in another room?
Not sure what you mean by 'bi-wire', but if you want to use the 'speakers as two separate pairs, say in different rooms, then I would put them in parallel and use the 4 ohm tap.
S.
I want to use them  one on top of the other in  the same room powered from the 500 amp , 2 speakers on the left channel and 2 on the right channel , linking the 2  speakers using bi wired cables
If I am explain myself , Not very good at the HiFuluting things
OK, understood. I would then put them in series and run them off the 16 ohm output as their bass units will be 'close-coupled' and so act as one. it will also make wiring easier as you just need one short cable between the two loudspeakers.
Why you'd want to do that, though, is unknown, as the lobing from the two tweeters will affect frequency response quite seriously.
S.
4 minutes ago, awkwardbydesign said:
Use the top one upside down?
That's what I would do, tweeter to tweeter, if for some bizarre reason had to use two loudspeakers like that. Better than the other way round or just one on top of the other.
One further possibility might be to use them back-to-back in a sort of pseudo omni arrangement, but I'm struggling to think of why use two pairs. If it's to increase loudness, the difference is only 3dB, so marginal.
S.
Its just a experiment by me , never done anything like that before , If they sound s-it it wont say in my system for long
Will try it though " Just in case " :D
Thanks for the imput , will report back when its done :^
Edited by Audio Al
Go for it! Experimentation, even if ultimately not an improvement is fun.
S.
Just a thought. Would it be a good idea to isolate one speaker from the other?
I was going to use some foam / bubble wrap or blue tack , see what happens :)
I'd just put something resilient between them, to stop the top one rattling against the bottom one. Blu-tack can leave marks on veneer but felt, fabric or thin rubber sheet will be fine.
S.
Gaffer tape will muller the cabinets all that glue :|
S.
I have a roll of blue rubber non slip matting , that should work
Crazy idea. :doh:
But I like crazy. :)
This reminds me of my old Rega Jura Supertowers. :D
Rega%20Jura%20SuperTowers_zpse0ehuzvg.jp
