Tune Audio Marvel horn loudspeakers
107 posts in this topic
I'd have gone for walnut, in the hypothetical world where I could afford these! Nice combo
Damn, they look stunning!
Horns with WAF - I suspect they'll generate a lot of interest so good luck with them Jack. :^
Mind you... I did immediately think of this.
:D
To add to the agony of choice we had American and European Walnuts in the selection. Naturally we went for the European in the end. :D
Martin, I may go to the Heathrow show dressed like that. :^
Jack
Marvels look pretty marvellous. Very few dealers in UK have been auditioning decent horns at reasonable prices and when I am next in the area I shall be sure to pop in. Also itching to hear David Haigner speakers. Does anyone in the WAM have a pair in the UK?
Regards
Paolo
Have a free Tune Audio Anima promo video from Munich, Jack. They did sound good there, forgiving the Aries amplifier aesthetics.
[video=youtube;kHtsd28P5pc]
Actually, playing the video through my liddle M&Ds pretty much proves they sounded good - making allowances for the shit mic in the camera...if you catch my drift.
I do wonder what they'd do with dub step, though:)
Thanks Justin, nice vid, I've sent the link to Manolis @ Tune Audio, he'll like that. :^
I'm not one for classical but I'm working through my genres today and Mozart has never sounded so good, I'm really enjoying it for the 1st time, I may have to extend my classical selection. Is Bigdur becoming cultured in his old age? :shock:
Is this a 2 way system Jack? ie with the Fostex(?) driver covering all bar the HF? Or is there another larger bass driver involved somewhere?
Got to say Jack That these look to be brilliant:^,
More than domestically acceptable:love: & look to be eminently practical in the context of average UK living rooms.....sadly the cost is way oot of my league...barring a windfall, just as well I seem to be in a happy place wiv regards to my current rig & other than possibly an SME 309 don't have any persistent itches at the mo (roll on any anusol comments recco's :roll::D)
The antimode dual core may b of some interest to me at some point in the future as it definitely intrigues me:cool: & another Wammer who I'm friendly with has recently bought one from you. I've recently done some measurements using a decent mike, my nanoface & the R.E.W. measurement suite & it seems that for the most part the in room measurements I've taken indicate my rig/speakers are pretty well set up & not massively compromised. I've recently added the mk2 crossovers & fine tuned the positioning & the gains have been more than subtle....I also have a large range of adjustments I can make to my speakers on the fly:^...so my current thinking is that I prolly need to do a fair bit of tinkering a lot more measuring & maybe investigate some of the more tasteful room treatment options prior to serious consideration of active room correction:?...I will definitely continue to follow the antimode thread & may look at the room treatment options from Paul at R.F.C. or even look at making some up myself as I'm a dab hand at knocking up frames etc. myself.
My take on it iirc :? from looking at the specs a week or so back on B.D.'s site was that its a two way...I only saw clear mention of two drivers & that the single :? 8inch driver was also horn loaded through the base of the cabinet for bass duties & that upper frequencies were care of a compression driver :? through the horn at the top of the cabinet & that the horn could be adjusted for correct beaming at the listening position. I'm more than happy to be corrected on any of these points tho' as I'm really not sure :D
It's a 2-way, crossed over at 2.5kHz. It doesn't say on the website what the topology of the horn is - it looks to me to be more of a quarter wave thing than a true back-loaded horn. How does it look from underneath? Is it pretty much empty inside, which would agree with this, or is there lots of woodwork inside, as you might get on a BLH?
Yes it's a 2 way, an 8'' radiating mids, rear horn loaded and downward firing bass driver. Highs are from a 1'' compression driver in a Tractrix horn.
Some specs
System Sensitivity: 97db
Impedance Nominal: 8ohms
Crossover @ 2500HZ
Recommended Power. > 5watt
Recommended Amplifiers. Low-mid powered tube or solid state with low or no feedback.
Recommended Placement. Near wall or room corner placement is desirable.
Preferred clearance between speakers >1.5 m.
Listening Distance. >2 m.
Dimensions.H149cm, W32cm, L56cm
Weight. 42Kgr each
It's a back loaded horn Adam.
Cool.
I also see that the US importer sells them for $17k. Since you've had to include VAT in your price, I say well done :^
Jack
Regards
Paolo
Hi Paolo, I had a look at D H speakers, some interesting designs, it'd be good to have a listen sometime, perhaps they may appear at Munich next year.
When you're passing give me a shout, it'd be a pleasure to demo for you.
Cheers,
Jack
