Due to a configuration issue, PayPal are currently configuring some changes for us therefore PayPal’s gateway is temporarily unavailable. We have set up a safe alternative gateway called Stripe so please use this for your Super Wammer subscription upgrades. Many thanks. Tech Team
The SEARCH function is currently under review due to a large number of old unstructured posts. This may take up to 1-2 days to complete. Alternatively, please use Google search; for eg: amplifier site:hifiwigwam.com/forum/
avinunca1
Connecting screens on phono amp cables
2 posts in this topic
I am using Van Damme cable with two conductors and a screen to connect up my valve phono amp kit .
I have connected one inner conductor to the screen at one end of each of the four cables. My intention is to connect the screen up at each phono input and output of the pcb and connect just the inner conductors to the RCA sockets on the back panel.
Is this correct?
It depends. I have a phono stage which has a floating input despite single ended conectors. While it will work with one leg earthed, if you leave that leg floating and connect the sheild to the case you effectively have a balanced input which MC cartridges respond well to. So cartridge and phono configuration can matter. However from what I can tell, what you suggest should work as a default.
