• advertisement_alt
  • advertisement_alt
  • advertisement_alt
Musicraft
Monitor Audio (+ News and Reviews) - At Musicraft (Derby)
82 posts in this topic
Dealer
8615_347046428755658_708861864_n.jpg?oh=02263867fd2f4a43934420ed72286ef2&oe=56F82FE9
Hi-Fi Choice reviews Monitor Audio's NEW Gold 200 speakers
http://ca2.monitoraudiocdn.com/downloads/HFC401_InDepth_Monitor_Audio_gold_Reprint-small.pdf?mtime=20150729134008
Gold-200-High-Gloss-White-on-white.jpg?mtime=20150105154121
Gold-200-150-gallery-1.jpg?mtime=20150107131053
Gold-200-gallery-2.jpg?mtime=20150107131104
Gold-200-150-W15-gallery-1.jpg?mtime=20150107131057
Gold-200-gallery-3.jpg?mtime=20150107131107
Gold-200-gallery-1.jpg?mtime=20150107131101
Gold 200, the first of new Gold's floor-standers is also the most compact. Amazing scale and impressive dynamic control are available from this slender three-way design, comprising the improved pair matched ribbon, twin 5.5" bass drivers and a 4" mid-range driver, which is housed in a dedicated enclosure. With high overall efficiency, wide bandwidth and vanishingly low distortion, the Gold 200's Platinum DNA is ready to be experienced.
- C-CAM® (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60KHz
- HiVe®II port technology for better transient response and tighter bass
- C-CAM RST® (Rigid Surface Technology) drivers
- Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
- Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
- Pureflow® silver internal cabling
- Selected premium quality wood veneer or high gloss lacquer finishes
- Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
- Invisible magnetic grille fixings provide a sleek visual effect.
***** Musicraft - Clearance + Special Offers list http://www.hifiwigwam.com/showthread.php?54367-Musicraft-%28Derby%29-Clearance-Special-Offers *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
Dealer
Monitor Audio's new Bronze 2 loudspeakers
Bronze-2-Walnut-on-white.jpg?mtime=20150501094442
Monitor Audio Bronze 2 loudspeakers
Bronze-2-Walnut-on-white-grille-on.jpg?mtime=20150501094454
Bronze-2-Walnut-pair.jpg?mtime=20150511091743
Tweeter-closeup.jpg?mtime=20150519120033
The Bronze Two builds on the strength of its predecessor’s audiophile cred with a neutral tonal balance and high detail resolution combined with high overall efficiency and power handling. These are the perfect ingredients for compelling listening. Armed with a larger 6.5” C-CAM bass driver and front-firing HiVe® port, the turbo-charged Bronze Two is capable of effortless dynamic scale and presence, revealing all the dramatic contrast in music and cinema sound. For a speaker of its size, the Bronze Two will deliver breath-taking results mounted on a stand and placed up to 8” (20cm) from a wall.
•New C-CAM® gold dome tweeter
•New 6 1/2” bass driver with concave ‘dished’ C-CAM® cone profile
•HiVe® port technology
•Single bolt-through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling
•High quality crossovers with premium grade Polypropylene film capacitors used throughout
•Rigid 18mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet coloration
•Invisible magnetic grille fixing
•Bi-wire/Bi-amp terminal configuration
•Premium quality vinyl veneer finishes
Thanks
Rick @ Musicraft
Dealer
Monitor Audio Bronze 2loudspeakers - What Hi-Fi Awards 2015 winner for Best stereo loudspeakers £200 - £400
http://www.whathifi.com/awards/2015/stereo-speakers
http://www.whathifi.com/monitor-audio/bronze-2/review
Thanks
Rick @ Musicraft
Dealer
Monitor Audio's new Gold FX loudspeakers
Gold-FX-High-Gloss-White-on-white.jpg?mtime=20150107110426
Monitor Audio Gold FX loudspeakers
Gold-FX-gallery-1.jpg?mtime=20150107130646
Gold-FX-gallery-2.jpg?mtime=20150107130650
Amazing as it may seem, the Gold FX's slim wall-hugging profile incorporates no fewer than six drivers. In monopole mode for discrete side or rear sound channels its front-firing 6 ½" RST® bass/mid-driver and C-CAM® ribbon transducer deliver accurate ultra-wideband sound to match the tonal balance of any 'Gold' speaker combination. In dipole mode the Gold FX uses two pairs of side firing 4" C-CAM bass/mid drivers and 25mm C-CAM gold-dome tweeters, combined with the tailored output from the front-firing bass/mid driver to provide wonderfully diffuse yet tonally precise surround effects. The Gold FX can be flush-mounted on side or rear walls. Installation is made easy by the inclusion of a 'sloppy fit' wall bracket, which allows levelling and adjustment prior to fixing.
• C-CAM® (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60KHz
• Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
• New C-CAM RST® (Rigid Surface Technology) drivers
• Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
• Pureflow® silver internal cabling
• Selected premium quality wood veneer or high gloss lacquer finishes
• Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
Thanks
Rick @ Musicraft
Dealer
TED magazine (Volume 22 Number 05) review Monitor Audio's NEW Gold 200 loudspeakers
http://ca2.monitoraudiocdn.com/downloads/reviews/MonitorAudio_Gold200_MagTED.pdf?mtime=20151102163256
"I knew the GX50 and their impressive bass performance very well, and I was expecting an even more percussive result with the Gold 200, I was not deceived!"
Remarking on the scale and quality of sound reproduction, they were amazed by the Gold 200's capabilities as it tackled a selection of music and film genres with ease.
"the impact and the depth of the bass are of of a level of quality rarely heard on speakers with such a small foot print"
"The voice reproduction is incredibly precise and three dimensional, the piano, the saxophone and the percussion are fantastic. The panorama of the two Golds extends across the entire front wall of my room, even if there's only two. I have to open my eyes to place them physically."
Monitor Audio Gold 200 loudspeakers
Gold-Tech-2.jpg?mtime=20150129104326
• HiVe®II port technology for better transient response and tighter bass
• C-CAM RST® (Rigid Surface Technology) drivers
• Invisible magnetic grille fixings provide a sleek visual effect.
Thanks
Rick @ Musicraft
Dealer
Canada Hi-Fi reviews Monitor Audio's Gold 300 loudspeakers
http://canadahifi.com/monitor-audio-gold-300-loudspeakers-review/
Gold-300-Piano-Ebony-on-white.jpg?mtime=20150105154622
Gold-300-gallery-1.jpg?mtime=20150107130922
Gold-300-350-W15-gallery-1.jpg?mtime=20150107130919
Gold-300-gallery-4.jpg?mtime=20150107130933
Gold-300-gallery-2.jpg?mtime=20150107130925
Gold-300-gallery-6.jpg?mtime=20150107130940
Standing at over a metre tall the Gold 300 is a majestic three-way floor-standing loudspeaker comprising twin 6.5" bass drivers, a single 4" mid-range driver and a high frequency ribbon transducer. With such an impressive complement of drivers, the Gold 300 has the power delivery and scale required to fill the largest rooms with jaw-dropping dynamics as well as the finest musical detail. Extending from below 30Hz to over 60kHz, its frequency range is among the widest available from any speaker, regardless of price.
• New C-CAM RST® (Rigid Surface Technology) bass/mid-range driver
Thanks
Rick @ Musicraft
Dealer
Monitor Audio's new Platinum Series 2 -
Everything will become clear
Experience the revealing chemistry of a purer Platinum
All will be revealed at CES,
Las Vegas, 6-9 January 2016,
Suite 29-140
Thanks
Rick @ Musicraft
Dealer
Monitor Audio's new PLATINUM Series II has received its world premier at the 2016 CES show, (January 6 - 9, Las Vegas). The range will be on display at the Venetian Suite 29-140
11215084_10153626902372025_6075716962916374652_n.jpg?oh=b53b6a8d575a8f6b7f13670c336668a9&oe=57429150
Monitor Audio's new Platinum PL500 loudspeakers
Thanks
Rick @ Musicraft
Dealer
Monitor Audio's new PLATINUM Series II at CES 2016.
12507169_10153630482657025_4280012099303213070_n.jpg?oh=5b83c8f8348518255e078ed100f1955d&oe=570ABABC
Monitor Audio's new Platinum PL500 loudspeakers at CES 2016
Thanks
Rick @ Musicraft
Dealer
Stereophile - Monitor Audio's new PLATINUM Series II at CES 2016
http://www.stereophile.com/content/monitor-audios-platinum-series-ii#DJWXoEEZeu5BzV1Y.97
Thanks
Rick @ Musicraft
Dealer
Monitor Audio will be exhibiting at Sound & Vision The Bristol Show (26th to 28th February) 2016 - Suite 1008 on the 10th Floor and in Room 208 on the 2nd Floor
***** Musicraft website - Special Offers list http://ww.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
Dealer
The Norwegian launch of Monitor Audio's Platinum Series II of loudspeakers takes place at Spaceworld Soundgarden in Oslo this weekend. Platinum PL200 II and Platinum PL500 II will be on demonstration with a full Hegel Reference 30 Series System comprising of a HD30 DAC, P30 pre amplifier and H30 mono/stereo power amplifiers
PL200_Black_720_Grille-Off.jpg?mtime=20151221142049
Monitor Audio's new Platinum PL200 II loudspeakers - RRP £6299/pair
It’s unlikely you’ll discover a more persuasive speaker than the PL100 II in its price class, but compare the floor-standing PL200 II with its smaller sibling and immediately you’ll notice the effect of four drivers in a larger cabinet. Such is the quality of Platinum II’s engineering that the character of the sound remains powerfully consistent and expressive, but with the addition of a second 6.5” RDT®II driver, the PL200 II’s bass has more weight, while its dedicated 4” RDT II midrange driver brings further definition to vocals and strings. Through the PL200 II, subtle textures are more vividly described and every note rendered with greater authority. It’s a factor of scale. Platinum II’s class-leading accuracy is a given, you simply need to match it with the size of your room.
PL500_Ebony_720_Grille-Off.jpg?mtime=20151222155044
Monitor Audio's new Platinum PL500 II loudspeakers - RRP £15000/pair
Measured against its peers, there is no finer audio ambassador than the majestic PL500 II. Here you’ll discover the essence of Platinum II engineering: silken layers of the finest high frequency definition suspended on an explicit midrange, seamlessly underpinned by a deep, clean and responsive bass foundation. More than ever the sound has a physical authority, conveying the ‘live’ character of instruments, voices and atmospheres as if they had materialised three-dimensionally in the air around you. This is fidelity in the raw, magnificent in stature, seductive for its rhythmic subtlety and utterly captivating in the sheer magnitude of its dynamic impact. Our most sophisticated system of no fewer than four 8” RDT®II bass drivers, twin 4” RDT II midrange transducers and MPD tweeter will render the entire harmonic sweep of every work with pin sharp timing and accuracy. Your music and film sound alive, immersive and uncompromised.
Hegel HD30 Digital Control Center in Silver finish - RRP £3200
Hegel P30 Reference pre amplifier - RRP £5000
Hegel H30 Reference mono/stereo power amplifier - RRP £11000/each
Hegel P30 and H30 Reference pre/power amplifiers
Thanks
Rick @ Musicraft
Dealer
Monitor Audio's new Platinum Series II
If a pin drops, you’ll hear it. When the orchestra plays, it plays for you, so vividly and with such effortless scale you’ll believe you’re ten rows from the stage. This is the magic of high-end audio as experienced through the Platinum II speakers. Whether it’s a power chord exploding from a towering backline, the majesty of a choir soaring in union or the spell-binding gravity of a solo performance, you’ll sense the chemistry of music and musician more than ever before.
For over forty years our work as engineers and audio enthusiasts has been dedicated to this unveiling. With our most advanced driver, crossover and acoustic systems set within luxurious cabinets, we’ve tuned the virtues that have won Monitor Audio worldwide acclaim to a new intensity, allowing rarefied audio transparency to be revealed and enjoyed. Platinum II is our magnum opus, as inspirational and satisfying to us as we hope it will be to you.
Platinum II Range
PL-Website-group-on-black-crop_2.jpg?mtime=20151221124919
• New RDT®II drivers with C-CAM® technology
• MPD (Micro Pleated Diaphragm) high frequency transducer, designed in-house for Platinum II
• HiVe®II High Velocity reflex port
• ARC® (Anti-Resonance Composite) mid-range driver housings and baffle components
• New patented 'DCF' (Dynamic Coupling Filter) mechanism for more natural sound
Platinum II Craftsmanship
P1000067-edit-for-site_2.jpg?mtime=20151221123934
The Platinum II cabinets are a statement of immaculate craftsmanship. Each is hand-built with the expert precision of the finest furniture makers, employing multiple laminations of veneer that are formed into a curved rigid shell. For the finish, natural wood veneers in Santos Rosewood or Natural Ebony are pair-matched, applied and hand-coated with 11 layers of clear gloss piano lacquer, then polished to reveal the glowing lustre in the grain. Platinum II models are also available in a penetrating piano black gloss lacquer, which will offer a luxurious contrast with room décor.
The front baffles are hand-upholstered with the very highest quality Inglestone leather supplied by Andrew Muirhead and used to distinguish many luxury British brands. Such is the level of care lavished on the Platinum II enclosures that each requires as many as 144 hours to complete.
Platinum II Technology
PL-driver-for-site_2.jpg?mtime=20151221124107
Platinum II offers you genuine audiophile performance with stunning design and materials specification. In the pursuit of ever lower distortion, no detail has been overlooked. Through meticulous FEA modelling we’ve optimised the operation of electrical, mechanical, magnetic and acoustic systems, introducing new discoveries to meet ambitious performance goals. The Platinum II range deploys an enhanced generation of RDT® bass and mid drivers, and for the first time in a Monitor Audio product, the MPD (Micro Pleated Diaphragm) high frequency transducer. Including improved crossover and speaker terminal designs together with proprietary ARC®, TLE, HiVe®II technologies, Platinum II builds on the award-winning advances of over forty years to create a high-end speaker range that is utterly faithful to the source.
Thanks
Rick @ Musicraft
Dealer
13095865_857636301029999_8927759219887799555_n.jpg?oh=b6ccde2b6f5b4fb1d8e3b0212ac0f09b&oe=57AE4DA5
Monitor audio are exhibiting at the High End Munich Show 5-8 May 2016, Hall 4, booth U04
Thanks
Rick @ Musicraft
Dealer
14947544_995216210605340_624824498225621
Monitor Audio Gold C350 centre speaker
Gold-350-Piano-Ebony-on-white.jpg?mtime=
The Gold C350 centre speaker is a no-compromise centre channel solution for serious home theatre installations. Its three-way, four driver configuration mirrors that of the Gold 300, although the bass drivers are tuned to work in the Gold C350's sealed cabinet. Unsurprisingly the C350 is the perfect match for its floor-standing counterpart, producing frequencies from 40Hz to beyond 60 kHz. A neutral tonal balance and distortion-free sound give the C350 the ability to project crystal-clear dialogue and mid-range detail at any volume.
Monitor Audio. Design for sound.
Gold-Tech-4.jpg?mtime=20150129104411
Monitor Audio Gold C350 centre speaker with Gold 300 main loudspeakers
Gold C350 Technology -
Gold C350 Specification -
• System Format 3-Way
• Frequency Response 40 Hz - 60 kHz
• Sensitivity (1W@1M) 90 dB
• Nominal Impedance (ohms) 8
• Maximum S.P.L (dBA) 113.8
• Power Handling - R.M.S. (W) 200
• Recommended Amplifier Requirements (W) 100 - 200
• Bass Alignment Sealed Cabinet
• Crossover FrequencyL.F - M.F: 800 Hz, M.F - H.F: 2.3 kHz
• Drive Unit Complement 2 x 61/2" RST® bass/mid-range driver, 1 x 4" RST mid-range driver, 1 x C-CAM® H.F ribbon transducer
• Cabinet Dimensions (HxWxD) 254 x 581 x 333 mm, (10 x 227/8 x 131/8 inch)
• Complete Dimensions Inc Terminals (HxWxD) 254 x 581 x 360 mm, (10 x 227/8 x 143/16 inch)
• Weight (each) 19.6Kg (43lb 2oz)
Monitor Audio Gold C350 RRP £999 (Dark Walnut Real Wood Veneer, High Gloss White Lacquer and Piano Black Lacquer. RRP £1199 (Piano Ebony)
***** Musicraft - Clearance + Special Offers List *****
Thanks
Rick @ Musicraft
